air fuel adjustments
xanmanz31Senior Member
- 218
michaelpSenior Member
- 9384
Originally posted by FilipeD'oh shit.
I want to learn something here…NA internals create for higher compression, right? Is that why you want to run lower boost? (as the compression is already higher than a turbo motor, therefore, needs less boost?)
Thanks.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 9384
Originally posted by BLOZ UPI'll send you a $1 with pp if you up the boost and destroy the rest of the engine, recording it all on video. With your phone sideways though, none of this vertical video crap.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 218
oh you guys.... you almost had me there
as fun as it sounds the whole 11 dollars id get for buying a go pro to record and the unknown dollar amount of damage id do to my car just doesn't seem to add up. -
BLOZ UPSenior Member
- 2971
$12, final offffer. man, 2 beerss.BLOZ UP.com
- 218
- 218
so just did my compression test and heres my #s
#2 - 170 psi
#4 - 180 psi
#6 - 180 psi
#1 - 185 psi
#3 - 180 psi
#5 - 180 psi
all plugs removed and plenum removed for test
what would cause a quiet knock / loud tick and compression not be effected? -
- 9384
Originally posted by xanmanz31so just did my compression test and heres my #s
#2 - 170 psi
#4 - 180 psi
#6 - 180 psi
#1 - 185 psi
#3 - 180 psi
#5 - 180 psi
what would cause a quiet knock / loud tick and compression not be effected?- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 218
elaborate
plugs #6, #3, and #1 were pretty black from carbon build up all the others look normal.
