Shiro for sale
PulseCodeSenior Member- 1522
Shiro for sale
My son found a Shiro for sale with a blown motor locally. I want to be sure that the original tranny/ LSD (and other stuff) have not been swapped out. Are there identifying marks/ signs by just looking under the car that I can employ to verify this? Thanks.Everything is Meaningless. -
GregmaticSenior Member- 2193
LSD on the Shiros *usually* have an orange sticker that says "LSD" on the side of the finned cover (have not found this on regular 87-89 turbo CLSD's). Also look for the telltale rib structure on the 30A tranny as well as the slanted shifter plate.
ozzyrulezSenior Member- 631
Or jack it up and get both rear wheels off the ground and spin a back wheel. Both wheels will spin the same direction if its a LSD, if it is open one will spin the opposite way. -
AlloutSenior Member- 182
If this helps, here's a visual of what the VLSD should look like:
1986 NA - Purchased by me in December 1985
Working on VG33 - NA to Turbo
Tokico Illuminas w/ Eibach Springs
88SS Sways -
Very helpful. Thank You- Allout. If time permits, I will post up some pics tomorrow of our find.Everything is Meaningless. -
Turns out this Shiro used to be owned by Felix (z31t) right here in Greenville SC.Attached Files- Shiro 1.jpg (96.0 KB)
- Shiro 2.jpg (90.2 KB)
- Shiro 3.jpg (91.2 KB)
- Shiro 4.jpg (98.6 KB)
More.Attached Files- Shiro 5.jpg (87.4 KB)
- Shiro 6.jpg (65.9 KB)
- Shiro 7.jpg (72.9 KB)
- Shiro 8.jpg (71.0 KB)
- Shiro 9.jpg (80.9 KB)
reddzxSenior Citizen- 6440
Buy it
1991 Hard-body 2WD
Rick88ssSenior Member- 2433
I wonder why it ended in that condition. Is it in a junk yard? The body doesn't look to bad. Poor SS.Shiro #443
The present owner has several projects going on and the SS is not top priority.
The clearcoat is pitted and the front lip is rough but, other than that, no bad body issues or rust.
I PM'ed Felix so, maybe he can chime in to add further details.Everything is Meaningless. -
Smells surprisingly well actually. The T-Tops don't leak at all and I was hard pressed to find any rust except a tiny bit in the usual hatch area.Everything is Meaningless. -
HarvesterUTMember- 74
I was talking about the mildew that is coating the steering wheel and dash.Originally posted by PulseCodeSmells surprisingly well actually. The T-Tops don't leak at all and I was hard pressed to find any rust except a tiny bit in the usual hatch area.
Both of mine had to be douched with a mix of white vinegar and water to get rid of that stuff.
#820 sat for a year or so under a tarp, #683 was parked in a similar wet/damp location to where this one is at.
