Very Stupid Question about Euro Lights
I've been interested in investing in Euro lights for my Z as I think they look a lot better up and I just think it'd be cool to have Euro parts on my Z. Someone recently pointed me towards searching the AUS forums as they have the single headlights as well, so I went and searched. I actually found a thread made by a US person and they had done a single headlight swap, however they said it took them forever to find a single headlight set because they had to get it from a German LHD Z? I'm a bit confused on this because I assumed wiring would not be that much different, and I'm just wondering if anyone can confirm whether or not you need a LHD vehicle in order to do the light swap. Very confused, please help. -
Lenses are unique for lhd and rhd.. the idea being they are less likely to blind oncoming drivers
some are subtle changes to the spread pattern, some are made with a bias to aim down at the corner -
Okay, that definitely clears up my confusion with the lense difference then. But does that mean I shouldn't do a swap unless I get LHD lights? I mean, I'd assume if I upgraded my lights to xenon it'd be just as bad if not worse than the RHDs…Originally posted by G-E View PostLenses are unique for lhd and rhd.. the idea being they are less likely to blind oncoming drivers
newsieoneSenior Member- 120
Not a dumb question at all. The head lights on our Z's dates to 1930's technology. The lights are 6054 (200mm) sealed beams set by DOT to 65Hi/55Lo watts. What you are looking for are conversion lenses to utilize new technology i.e. 9004, H2, H4 bulbs. HID lights are another story.
"Pilot", "Rampage" and "Hella" make conversions for our cars. All avail on the net.
I chose to use Hella lense kits which I got from www.classicgarage.com. Kits were complete with 65/55w bulbs but I also bought a set of 100/80w ("off road" bulbs to fit). I use only the 100/80 and have had zero problems blinding others and no hassles from the fuzz.
Should you go this route, I recommend using "headlight pigtail adapters (Dorman $5.00) etc. The new halogen lights are hot and tend to cook our old wires. The changeover is simple (except for the rust)
86na
88t -
floridaZSenior Member- 2781
For what it is worth, I wouldn't hesitate to put RHD lenses on a LHD car. Simple fact is that even with stock suspension, a Z31 sits with the headlights of most vics on the road right at eyeball height. So the chances of you blinding oncoming traffic with RHD housings and a non-HID bulb are pretty small.Feedback- viewtopic.php?f=18&t=19840
