What is this bracket?
 wbnethery3Senior Member wbnethery3Senior Member- 437
 What is this bracket?I was going through my stuff, and I took this off the car so long ago that I cannot remember where it went… I did not "bag and tag" like I did when I started getting into the engine, so I'm clueless.
 It is obviously meant to brace two lines of some kind, not sure if brake or fuel. So… anyone have a quick answer? If so, help an old fart out and remind me…'86 NA - original owner (1986-93) and final owner (2005-present)
 Ground cable bracket that goes on the frame rail near the starter area.
 Axel kainModerator Axel kainModerator- 1221
 ^ yeah, on the frame rail top side, near where the damper sits, holds the primary power and ground cables.Damn dirty angels....these cars!
 sigpic
 Thanks guys… search doesn't really work for that sort of question, so appreciate the help.'86 NA - original owner (1986-93) and final owner (2005-present)
 Well… I looked at it tonight, and still trying to figure out how it goes on… in the process I found NissanEgg's build thread on BamaGZ. Wow, that's quite a build thread - with lots of pictures. I'm sure there may be one that shows where it goes… it's interesting reading, whatever the case.'86 NA - original owner (1986-93) and final owner (2005-present)
