oil filter location
z31armoJunior Member- 3
oil filter location
Is there anything that can be done about the location of the oil filter to make it easier to work on? Anything?!?!? -
reddzxSenior Citizen- 6440
Whats the problem, and why would you need to work on the filter? Its not that hard to remove from underneath.
1991 Hard-body 2WD
amrebootBanned- 9875
NissanEggSenior Member- 5220
I take my starter out each time so I don't get oil on it (have the external oil cooler setup). Still can do it from underneath in less than 10 minutes.
88sinZSenior Member- 2019
Old tip:
Use a punch to create a small hole at the filters low point, leave the punch in the filter body. Have a catch cup handy, hold below the hole and remove the punch. The oil from the filter will drain for disposal. Now when the filter is removed it will not burp oil all over your starter/wiring.
I remember a member created a 'tongue' that bolted to the block to route oil draining from the filter away, can't remember who… -
mtherkampSenior Member- 243
If you take the cruise control actuator loose from the fender and move it out of the way, you can get to the filter MUCH easier. Those of us who have deleted cruise probably have forgotten how much this obscures the filter, especially if you are still running PS. When I first got my Z, I couldn't even FIND the filter, with all the stock stuff in the way. I did the first oil change from underneath, but realize now that that isn't necessary if you get that cruise actuator out of the way!Butter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard."
