Need to lengthen my driveshaft....
midorizxJunior Member- 20
I'm in the process of doing an automatic to manual swap on my 84 Z (2+2), and my parts car was an 85 coupe with the FS5W71C manual transmission. I know I'm going to need to get the driveshaft lengthened (searched all my local junkyards, no Zs to be found, sadly), but I was wondering if there were any other changes that need to be made to the driveshaft. I read on here ( http://www.xenonz31.com/Driveshaftinfo.html ) and it seems like there are no differences in the flange. Any help or advice with this would be appreciated. ^_______^
oh! btw, both are non-turbo models. -
reddzxSenior Citizen- 6440
any 84-86 2+2 manual drive shaft will be a direct fit. It shouldn't be to hard to find one.
1991 Hard-body 2WD
I couldn't get any driveshaft shop to lengthen one, because theyre metric sized tube. I had a brand new driveshaft made for my swap by shaftmasters.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
amrebootBanned- 9875
+1 on shaftmasters.
Incredible customer services. They know all Nissan terminology in regards to models, transmission, and diffs.
When I talked to Dave @ shaftmasters, I told him of my custom transmission to subframe swap utilizing the 350z r200, and all Dave said was "now thats freaking cool!".
Product was fantastic. -
The box it came in is probably as strong as the stock driveshaft, let alone the new 3" shaft with awesome easily-replaceable ujoints. haha I kind of wish I went aluminum, though.
nismopuAdministrator- 2221
you guys cant find a DS shop to re tube driveshafts?"Its the s12's sexy over weight step daughter, the z31" -
Looks like xenonz31's images aren't showing up on his site anymore.....anyone have a link to the different measurements on the driveshafts? -
wbnethery3Senior Member- 437
They reworked their website, but I think most of the info is still there… use this link to get to main page, then hover over the drop-down menu for Z31 at the top:
http://www.xenonzcar.com/z31.html
I think the specs you're looking for are here:
http://www.xenonzcar.com/z31/Driveshaftinfo.html'86 NA - original owner (1986-93) and final owner (2005-present)
