Z31 fan shroud
Sailingary77Junior Member- 4
Z31 fan shroud
I've got an 85 non turbo and having trouble with the fan shroud , I had my Rad serviced and just can't get the dam shroud back in properly , seems that it needs some fasteners on the sides ?? Any advice ? Thanks and happy 4th to all -
1artworkzSenior Member- 1143
boosted300Senior Member- 195
Thanks I'll give them a try , look perfect . I had my fan eating away at the shroud which ended up in a bent water pump shaft , replaced everything including the timing belt and ended up with the big washer that goes on the crank shaft to hold the belt in place , left off .. 😕 it's been running fine for a few months without that washer , should I need to worry about that , it's a total pain in the ass to take everything apart again but if it's gonna cause me more problems down the road ? Please advise thanks much -
So is it a big problem not to run with the timing belt retainer washer that goes on the crank shaft ? -
amrebootBanned- 9875
