for those who have rebulit heads and the block....(question)
 evpenaSenior Member evpenaSenior Member- 152
 for those who have rebulit heads and the block....(question)I have an 86 z31t motor. i have rebulit the block and and in the process of porting and rebuliding the heads. the question i have is how difficult to have the timing corrext when putting the motor back together. i been talking to a couple mechanics about it and they seem scared and unsure. any info would be greatly appreciated.
 nutsaqSenior Member nutsaqSenior Member- 208
 its no different than a timing belt job, you put the belt on so all the lines match the marks on the cam and crank gears and you are done. turn it over a couple times by hand if you are worried about it. Getting the distributor back in right might take a couple trys
 SATANSenior Member SATANSenior Member- 6782
 40 belt teeth between the cam dots and 43 belt teeth between driver cam dot and oil pump dot.85 Z31 6.0 LSX turbo 766whp/792wtq
 steer clear of thoes guysevpena wrote: Ii been talking to a couple mechanics about it and they seem scared and unsure..
 Rule #1 in that trade, Always pretend you know what your doing :gni when in doubt check the books
 are the valves or the pistons supposed to be aligned any way before i mount the heads on the block. when i took it off the heads and belt i had it on the marks but wondering if it is different after the heads and block have been rebulit?
 This is a great place to get help, but theres lots of info in the haynes, chilton, and FSM on your questions
 rebuilding a motor wont change its timing
 OrionMCPSenior Member OrionMCPSenior Member- 349
 Just set the #1 piston at tdc and set the camshaft gears to the alighnment marks before you reinstall the heads. Its not too complicated.evpena wrote: are the valves or the pistons supposed to be aligned any way before i mount the heads on the block. when i took it off the heads and belt i had it on the marks but wondering if it is different after the heads and block have been rebulit?
