Replacing The Heads On 84 Turbo
greedy13nkMember- 40
So I just picked up my new rebuilt set of heads with cams and valves etc. what else will i need to replace when replacing the heads i know i'll definitely need head gaskets what other things will i need to buy?'84 300zxturbo 50thAE 5spd@10 psi
'85 300zxturbo auto -
datsunzcar84Senior Member- 740
Get your self a good quality "Head Set", not Felpro they IMO are junk.
You should also consider doing the timing belt, timing belt tensioner , water pump , and cylinder head temp sensor while you have it apart .D@MN IT FEELS GOOD TO BE A GANGSTA
