pathy distributer
13PsiPleaseSenior Member- 345
pathy distributer
Why do you need to replace the z31 D for the pathy d while doing the intake plenum swap. I read the how-to but it never says why you have to and i dont see why the stock z31 D wouldnt work.Blitz BOV, Walbro 255, HX-35 (8psi), Tokcio blues and lowering springs. -
sreich05Senior Member- 254
to tall for what. Hitting the plenum or somthing?Blitz BOV, Walbro 255, HX-35 (8psi), Tokcio blues and lowering springs. -
brewster240Senior Member- 150
OrionMCPSenior Member- 349
If you really have to use the Z31 dizzy, you can trim the plug connection down to clear the manifold.(not reccomennded.) IIRC you can use a maxima cap or something that will work with the Z31 dizzy and the pathfinder manifold. someone chip in if Im wrong. -
DmanSenior Member- 313
88 maxima cap on a z31 dizzy will clear the pathy plenum........OrionMCP wrote: If you really have to use the Z31 dizzy, you can trim the plug connection down to clear the manifold.(not reccomennded.) IIRC you can use a maxima cap or something that will work with the Z31 dizzy and the pathfinder manifold. someone chip in if Im wrong.Denis Gagné
aka VGwagon
GM specialized licensed technician
69 510 VG30 powered wagon
73 240z shell VG30et in progress
86 300zx NA2T
