86t timing with early 87 crank pulley
Sharpen047Senior Member- 507
Hey guys, im trying to check the ignition timing on my z, its an 86t and has an early 87 crank pulley with different marks on the crank.(for using a titan alternator with the a/b series engine) the timing cover with the pointer is from my stock 86 stuff. is the 87 one in a different spot? the timing doesnt even show in the marks. the marks end up around 10 o clock on the pulley.
any help would be great. thanks. -
88sinZSenior Member- 2019
your further most LEFT mark is 0° each mark is a 5° BTDC increment.
If they don't line up you're ether not near TDC or your timing is off. -
shromySenior Member- 2189
probably 180 out. 2 crank revolutions for 1 cam revolution.Hmmm, Whats next?
84ZXT
