Solid mount questions
 itsnathanJunior Member itsnathanJunior Member- 7
 Solid mount questionsI'm interested in replacing my mounts and bushings, I want to upgrade to poly/ solid so I wont have to worry about them ever again.
 I have come across Stubby solid motor mounts on ASCO, vibrations aside being able to lower the engine to be able to install a Pathfinder plenum sounds good to me.
 My concern is how things will line up, for the transmission ASCO has Polyurethane mounts, will they do fine with the engine being lower on solid mounts, will I need something specific?
 Thank you
 nismo kidSenior Member nismo kidSenior Member- 785
 You should be fine. FlawleZ has ran custom solid mounts with a factory transmission mount for over 2 years. While making 545 RWHP/540 RWTQ.Originally posted by Racinjitter:lol: Those of us who say A/C FTW all have a g/f or wife. ac+women=more quiet=possibility of sex. -
 ac+women=SUPER BITCHING=no sex.
 Just get the polyurethane mounts.
 Don't install the pathfinder intake if you plan to go turbo, it's a bad choice.
 Is your car even running?
 mtherkampSenior Member mtherkampSenior Member- 243
 I'm running solid z32 motor mounts, vibration is not noticeable around town, but I have a pretty good buzz at ~80mph indicated, although that might be drive-line related since I have an aftermarket driveshaftButter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard."
 I don't plan to go turbo, and the car is running. My choice would be Poly but since the solid mounts lower the engine I was interested in getting them instead.Originally posted by 88sinZ View PostJust get the polyurethane mounts.
 FrozenZSenior Member FrozenZSenior Member- 584
 Axel kainModerator Axel kainModerator- 1221
 I have solid with my 270 cams. only notice anything when idling, and even then it's barely worth mentioning. otherwise it's just fine all the way to/through 6k.Damn dirty angels....these cars!
 sigpic
