Okay to use wheels that aren't hub centric?
areebashar.23Member- 48
So I got a set of wheels for hella cheap and imo they look kinda nice. Problem is the offset is a bit off so I'm thinking of hub centric spacers to fix that. On the other hand, the rims aren't hub centric so they're a little bigger. Can this still work? Like a hub centric spacer spah a non hub centric wheel? Still safe? -
Some would argue that just using spacers is not safe, so it's all ultimately up to what you feel comfortable with.
If the wheels you are trying to use were made for conical lugs, then that may be enough to keep the wheel
centered on the hub. If not, they i would definitely look for a hubcentric adapter ring, or have one fabricated from aluminum.
Try researching if there is an adapter ring that will match the hub diameter of the z31 (66.1mm) and the inner diameter of your wheels.
That being said, I use 20mm spacers on my wheels, the plastic hubcentric adapter rings the wheels came with and conical
lugs and have never had an issue.
- 1 like
kaurSenior Member- 310
What do you mean when you say they're not hub centric? Do you mean they have a larger center bore so that your hub doesn't center them? Or are they generally not installed as hub centric? If they just have a larger center bore, then that is easy to fix with spacers or centering rings. Otherwise find out how they're normally centered and see if you can do the same on your spacers. -
260DETSenior Member- 537
With tapered fit wheel nuts the wheel is located concentrically by the nuts and clamped against the hub when the nuts are tightened to lock it in place and prevent it moving. -
So i mean like the center "hole" is larger than the hub thing that protrudes out. Like the wheels kinda sits on the lugs so to sayOriginally posted by kaur View PostWhat do you mean when you say they're not hub centric? Do you mean they have a larger center bore so that your hub doesn't center them? Or are they generally not installed as hub centric? If they just have a larger center bore, then that is easy to fix with spacers or centering rings. Otherwise find out how they're normally centered and see if you can do the same on your spacers. -
Not gonna lie, I have almost no clue what you said, and I tried googling half of it too lmaoOriginally posted by 260DET View PostWith tapered fit wheel nuts the wheel is located concentrically by the nuts and clamped against the hub when the nuts are tightened to lock it in place and prevent it moving. -
PaceModerator- 1108
Some reading info related to this topic: hub centric vs lug centric wheels. http://www.gregsmithequipment.com/Hu…Vs-Lug-Centric
To snugly fit a wheel with bigger center bore onto your car you either get hub rings or hub/wheel-centric spacers (Motorsport Tech offers custom made spacers for this). Alternatively you can also center the wheel via lug centric methods (what 260DET referred to) but it may be more susceptible to vibrations and/or more in-depth balancing.'86 300ZXT GLL
'78 Datsun 280Z BP
'11 Saab 9-3 Aero XWD -
Basically what I'm saying is that tapered wheel nuts LOCATE the wheel in relation to the hub. But it is the wheel being clamped against the hub when the nuts are tightened that stop the wheel from moving when the car is being driven.
- 1 like
FlawleZSenior Member- 1971
He's saying with the proper lug nuts, the wheel is mounted and centered based off the lugs and lug nuts. AKA lug centric.Originally posted by areebashar.23 View Post
Also, if you need to correct the offset on your wheels with spacers, use wheel adapters instead. They can provide much more spacing while retaining the lug centric mount of the wheel.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
- 1 like
