E-Brake Repair
Bates Z31Senior Member
- 202
E-Brake Repair
So I just got back into a Z after many years. Itâs an 87 NA 2+0 5 Speed. One of the biggest issues it has is the E brake not working. Itâs actually the first car Iâve had that has e brake issues so it is a new territory for me.
The handle has nothing to it which is leading me to believe the cable broke. Where should I start troubleshooting this issue? Thanks. -
mwolvinmSenior Member
- 249
Jack up the rear of the car. The e-brake cable connects to the rear calipers on the bottom side. Have someone actuate the handle and see if it's moving at the caliper end. If not, then it may well be a broken cable. If it is moving, then it may just need an adjustment.--------------
Legal stuff:
**Nissan Employee**
not legal stuff:
'00 Corolla-- kids car.
- 202
Originally posted by mwolvinm View PostJack up the rear of the car. The e-brake cable connects to the rear calipers on the bottom side. Have someone actuate the handle and see if it's moving at the caliper end. If not, then it may well be a broken cable. If it is moving, then it may just need an adjustment.
Sounds simple enough. How difficult is the cable replacement? I have the FSM just to get a general idea what Iâm working with but have yet to find a guide on replacing it for a Z31.
Also is the adjustment piece under the car in the back by the rear subframe?
Z_KarmaAdministrator
- 3318
Cables are relatively easy. Un-bolt the handle cable at the union just in front of the subframe. The rear cables run through guide tubes that i find easier to just unbolt
than to try to push them through while they are still attached at the caliper. Once they are free of those tubes, release them at the caliper. Install is reverse.
Replacement cables are available through Rockauto or Amazon
Left: Wagner BC138673 (Cheaper on Amazon)
Right: Wagner BC138671 (Cheaper on RockAuto)
- 1 like
- 202
Originally posted by Z_Karma View PostCables are relatively easy. Un-bolt the handle cable at the union just in front of the subframe. The rear cables run through guide tubes that i find easier to just unbolt
The car also also seems to have a draw at the headlight. Is this a common issue? My other Zs never had it.
- 3318
If rust is an issue, i'd start inspecting ground points on the engine bay harness, and any connections on that engine bay harness in general.
Sometimes you can rehab brake cables by squirting some silicone lube down the cable and try to work it back
and forth, but I've found it's only a temporary solution, especially in rainy conditions. I've had them freeze before because of moisture in the cable sheath.
- 202
Originally posted by Z_Karma View PostIf rust is an issue, i'd start inspecting ground points on the engine bay harness, and any connections on that engine bay harness in general.
- 249
Thanks for the links to the cables Z_Karma… I actually have a bad one myself that needs replacing. I can engage the calipers just fine.... but disengagement requires a trip under the car with a hammer to the driver side only. I discovered it wasn't the caliper when I unhooked the cable over the weekend.
Bates-- I thought rust holes in the exhaust were there to help the car pass emissions…--------------
Legal stuff:
**Nissan Employee**
not legal stuff:
- 1 like
- 202
Originally posted by mwolvinm View PostThanks for the links to the cables Z_Karma… I actually have a bad one myself that needs replacing. I can engage the calipers just fine.... but disengagement requires a trip under the car with a hammer to the driver side only. I discovered it wasn't the caliper when I unhooked the cable over the weekend.
Bates-- I thought rust holes in the exhaust were there to help the car pass emissions… -
- 202
Quick update. I found the ebrake culprit but canât fix it yet. By the adjustment near the rear crossmember, the equalizer had gotten destroyed so the second cable leading to the calipers is not currently mated to the first cable coming off the ebrake handle.
If anyone knows where where I can get this little piece please let me know and thanks for your help.Comment
