What color is the ignition ON wire?
SynthwaveIntensifiesJunior Member- 22
What color is the ignition ON wire?I installed some electric fans and I feel like I wired it wrong because I tapped the red/white striped wire and the fans are still able to turn on when the car is off no key in the ign. I don't have a multimeter to poke around and find out either.
Edit: Nvm it was the black/white striped wire in case anyone else needs to know.Last edited by SynthwaveIntensifies; 07-02-2019, 10:09 AM. Reason: Solved -
FlawleZSenior Member- 1971
Thanks for updating for others. Theres several ways to add accessories like Efans. I recommend purchasing an inline fuse that you can insert in the fuse panel that has separate leads to power something new. This will keep from having to splice into your factory harness and likely save future headaches.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
