Wideband Sensor
sp3cialfxMember- 34
Wideband Sensor
Can I put my Wideband O2 Sensor in the stock location and remove the stock sensor? Will the Wideband get a good reading there? Will it burn up there?
Powered by Fund Solvaren. -
88sinZSenior Member- 2019
Probably not, ideally you want it 18"-24" (45-60cm) after the downpipe. Fitment will depend on the sensors thread and bung
Even then, there's not much use for one unless you are going for tuning the ECU or stand alone management systems
