downpipe studs
pizza boys ZMember- 55
downpipe studs
i just installed a cm downpipe, but the stock studs are too short. how do i swap these out for longer studs? do they pound out like a wheel stud or do they turn out like a head stud?1988-turbo-full CM 2.5" catless exhaust, synapse bov, MSA short throw, 10psi -
AlloutSenior Member- 182
They're threaded like a head stud or an exhaust manifold stud.pizza boys Z wrote: i just installed a cm downpipe, but the stock studs are too short. how do i swap these out for longer studs? do they pound out like a wheel stud or do they turn out like a head stud?1986 NA - Purchased by me in December 1985
Working on VG33 - NA to Turbo
Tokico Illuminas w/ Eibach Springs
88SS Sways -
alright thanks alot, i just didnt wanna go under there and start messing stuff up.1988-turbo-full CM 2.5" catless exhaust, synapse bov, MSA short throw, 10psi -
mace350Senior Member- 396
DeleriousZSenior Member- 6874
double bolt trick!!
1990 jetta vr6'd -
whats the double nut trick? put one on, and back it against another one to remove the stud?1988-turbo-full CM 2.5" catless exhaust, synapse bov, MSA short throw, 10psi -
yep, you even called it by the right name lol.
1990 jetta vr6'd -
yea, im not a noob haha, just wanted to make sure before i screwed it up.1988-turbo-full CM 2.5" catless exhaust, synapse bov, MSA short throw, 10psi -
