Stock Crap that can be removed
cerealwarsMember- 75
viewtopic.php?f=24&t=25258Any update on the Power Steering removal?
I wanna do it to mine since my pump and everything is out.
1985 330Z
ZEricMZSenior Member- 455
Im just wondering so I can start on my a/c removal, does anyone have the belt size for the pulley after you factor out the a/c pulley being gone?Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
Matt89Senior Member- 2380
If you feel the need to ask for further info than what is posted in this thread about removing components then you should really leave your car alone.Bolt on, fast, z31. You can only pick two.
alexbre00Senior Member- 123
i just wanted to know if there was a different thread for the n/a vacuum removalMatt89 wrote: If you feel the need to ask for further info than what is posted in this thread about removing components then you should really leave your car alone.88 n/a automatic 9/87 - blown up/parts car
87 n/a 5speed 9/86 - daily driver
87 turbo 5speed 6/87- project -
midorizxJunior Member- 20
what would happen if I totally removed my intake collector, idle-up solenoid valve and FICD? I noticed some other people removed it altogether and blocked it off.
I have a reason. -
tatsuSenior Member- 222
Pretty cool, I know what I'm gonna do to my z once I get it from my friend haha
https://fund-solvaren.com.Non turbo, 200K+ mile club, 60mm TB, 149WHP 168WTQ -
vgterian94Senior Member- 645
With both of my cars apart, I had forgotten where the coolant lines from the turbo are supposed to go if the plenum coolant hardlines were bypassed.DeleriousZ wrote: http://www.tboz31.com/
under 'writeups'
Using TBO's setup, can I connect the coolant hose from the lower intake plenum to go into one line of the turbo, and then connect the coolant from the heater-hose 't' to the remaining turbo coolant line.
If the turbo coolant lines feed off the plenum hard-lines, then the above should be should work.........?
demonics12Junior Member- 22
so, if i wanted to swap a pathfinder manifold on, i could block off everything?
idk if anyone knows, just thought id ask
yes, I run 0 idle controls or EGR or anything on the intake on my 84.demonics12 wrote: so, if i wanted to swap a pathfinder manifold on, i could block off everything?
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
slammedfcSenior Member- 288
Considering nobody has complained or argued against the iac valve removal it's a good option?
I have a large pile of stuff for a project i'm working on and if i so choose to use a stock ecu, it's able to compensate well for idle/cold start?
Stock injectors/maf?
I've removed it on my cars and a few friends cars and all i had to do was adjust the throttle stop. Still, i was at the mercy of air density and temperature. If it was too cold or humid, i had either starting issues or idling issues depending on car. Not all ecu programming is the same. That's why i ask.
Thanks. And if my post doesn't belong here you're welcome to have it deleted.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
FrozenZSenior Member- 584
In case anyone is wondering:
A/C removal from the firewall forward*: 42 pounds.
Removing the cruise control: 3 pounds.
Seeing daylight in your engine bay: priceless.
* Including all lines, compressor, mounting bracket for the idler pulley, condenser. Not including the compressor bracket (because my alternator's hanging from the bottom of it) or up to 1.5lbs of refrigerant and maybe a pound of fasteners. -
i removed all AC firewall forward, and power steering..with a 2+2 with T-tops i sit right around 3050lbs on the scale
I removed ALL the heating and AC and i need to get my car re-weighedNon turbo, 200K+ mile club, 60mm TB, 149WHP 168WTQ -
Axel kainModerator- 1221
Let me just say what I do have. Idle control.
No- a/c. P/s, aiv, cat, pre turbo plumbing, tps, egr, or coolant piping above the lower intake mani. Runs great! Drives nice too!Damn dirty angels....these cars!
sigpic -
Once i get my motor out im going to block off the plenum stuff that i don't use..my car happily idles at 800rpm with no help
though my last dyno run made it to where my car doesn't want to idle anymore…no idea why…Non turbo, 200K+ mile club, 60mm TB, 149WHP 168WTQ
