A/C Drier/Low Pressure switch question.
GenyaMember- 50
Hey my replacement a/d drier doesnt have a Low Pressure switch. Will this have ill effects? Does it move over to the new unit? Unsure, thanks. I noticed a/c doesnt turn on compressor, but I wired a toggle switch to by pass that directly to compressor switch so that engages. -
jn1czSenior Member- 1520
The ill effect of not having a low pressure switch is that your compressor will never kick on.Genya wrote: Hey my replacement a/d drier doesnt have a Low Pressure switch. Will this have ill effects? Does it move over to the new unit? Unsure, thanks. I noticed a/c doesnt turn on compressor, but I wired a toggle switch to by pass that directly to compressor switch so that engages.
Yes use the old switch or buy a new one. Use a new o ring if you didn't get one w/ the receiver/dryer. -
GenyaMember- 50
Thanks for the reply, I used a fused rocker switch and placed it in the dash spot, and it engages the compressor for a/c. It Replaced the 3 vacumn lines from the underhood cansiter and blows cold, but for life of me working on getting the air to go through vent, so more diagram following looks like. -
Ok but you need that low pressure switch. It's a failsafe for the system. If your freon leaks out and your compressor keeps engaging say byebye to the compressor.Genya wrote: Thanks for the reply, I used a fused rocker switch and placed it in the dash spot, and it engages the compressor for a/c. It Replaced the 3 vacumn lines from the underhood cansiter and blows cold, but for life of me working on getting the air to go through vent, so more diagram following looks like.
