ECU Fried?
carbonarcJunior Member- 4
ECU Fried?
Building a racecar and today we put the ECCU back into the car - it was stored in a safe place over the last month. Now she won't start - cranks fine but no spark. Turning the potentiometer it to diagnostics mode and nothing - neither led lights up, but there is 12v to pin 114 which is the main power in from what I understand. The ground is good. Any ideas or source for an ECU? 1987 non-turbo. Thanks, Curt -
fusible links?carbonarc wrote: Building a racecar and today we put the ECCU back into the car - it was stored in a safe place over the last month. Now she won't start - cranks fine but no spark. Turning the potentiometer it to diagnostics mode and nothing - neither led lights up, but there is 12v to pin 114 which is the main power in from what I understand. The ground is good. Any ideas or source for an ECU? 1987 non-turbo. Thanks, Curt
fuses?
battery relay?
