Maxima Oil Filter Location
sprtcrazy17Senior Member- 1685
From what I've read I understood VG30 blocks are all the same essentially. This is from a 91 I believe, maxima. The oil filter is in the way of the exhaust manifold. And it has this goofy design to it that puts in directly in its path. Anyone seen this before? And know of a way or some part to adapt a filter to come straight of the block?
Also looked at this and mentions nothing of it… http://z31.com/repairs/newengine.shtml
Thanks
Found a guy with this setup..
Then found this kit on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayI … 0459307314
I don't need to go with a remount kit but I hope this isn't the only option
junior85zSenior Member- 285
cant u transfer the threaded fitting to screw on the filter, from ur AE to the max? I believe you need a 22mm socket for the AE fitting and a standard screw driver and hammer for the max fitting -
Matt89Senior Member- 2380
Exactly, just swap in your threaded one.Bolt on, fast, z31. You can only pick two.
