Getting New Tires.
NissanXRMASenior Member
- 3245
Getting New Tires.
Okay so i need tires for the Riken 16x8" for it to fit in wells. These are the tires on it right now. 255/50/16
The tires need to be scaled down.
I was thinking of 225/50.
I was also thinking of 205/50. I really don't want much of a stretch at all. Maybe the littlest if i have to to fit them.
By the way wheels will be polished and the centers gloss black. -
TurboDreamsBanned
- 1127
Is 205 even considered a stretch for 8 inch width wheels? I know its ungodly wide on 6 and 6.5 inch wheels I'd probably go for 225 though, wide is good. -
- 3245
supertoad120Senior Member
- 165
I wouldn't go any narrower than 225's, but that's just me. I actually want to replace my 225/50's in the rear with 255/50's to get a little more rubber on the ground.1987 N/A-to-Turbo
VG33ET
Holset WH1C
Stance Coils
viewtopic.php?f=13&t=15468 -
- 3245
My 255/50's are too big for my situation. I'd sell em to you if you were close for a good deal. They're practically brand new. -
- 3245
85z31t88Senior Member
- 867
just saw this post… I have 215/55r16 falkens going on my 16x8 bbs wheels. (this size is the correct size so the speedo wont change)
215/45r16's are going to be too small. They measure close to 23.5" tall. Stock tire height is right around 25". Your speedo will read faster than you are actually going.
check this website out:
http://www.rimsntires.com/rt_specs.jsp'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
2015 Ram 2500 megacab laramie cummins black appearance package -
- 3245
vagabondSenior Member
- 3455
- 867
225/50r16, stock tire size'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
- 3245
- 3455
- 867
check out the website i posted above and decide what is right for you. Enter the tires you have on the wheels now with offset, and use the deal to figure out what you need to clear. It will give you dimensions and everything using offset.'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
- 867
215/50's will work, but your speedo will be off some.'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
- 3245
My wheels also have a negative offset of -5 and have IC piping to get around, and to clear the fender.
