BodyKits for the Z31?
  • WarOnFlesh
    WarOnFlesh
    Member
    • 72
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    Originally posted by WarOnFlesh View Post
    I don't know if they were omitted purposely, but Proudear makes some Z31 stuff:
    http://proudear.shop-pro.jp/?mode=ca…d=22124&csid=1
    No .. At the time the body kits page was created .. Not too much was known about Proudear.
    But your response is exactly what I hoped would be generated. Links to additional sources.
    '84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
    Originally posted by maronee
    PS - by the way your Z31's famous here in japan, dude!!
  • Pauls
    Pauls
    Member
    • 64
    Proudear gear is tempting even though a lil expensive for most.
    You might find some extra goodies here; http://www.zdriver.com.au/index.php/…uki-body-kits/
    Love z31's as much as I do? Check out my build: http://www.zdriver.com.au/index.php/…__80#entry2219
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    Thanks .. For those that don't want to sift through that forums thread .. Which showed lots of Proudear products .. I did note this one ..
    http://kanazawa-bodyrepair.jp/info/?p=5635
    BTW .. There are 3-4 fab shops, including Proudear .. All in the same general location. Some mfg the same products .. Some have exclusive items ..
  • Switchback Motions
    Switchback Motions
    • 705
    #5
    That's Kei's car. Must be who helped him with his build.
  • Pauls
    Pauls
    Member
    • 64
    #6
    Does anyone know how to get in contact with Kei?
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    #7
    He's currently vacationing .. Germany, I believe.
    Easiest way is via FB.
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    #8
    I noted it was Kei's .. No doubt your observation is "spot on"
  • feelzpower
    feelzpower
    Junior Member
    • 4
    #9
    Autostyle-usa bit pricey though
  • Pauls
    Pauls
    Member
    • 64
    #11
    Back in the day I had a 1 piece front bar that looked more ferrari like with side skirts on my s1 turbo and was branded autopia.
    Rather than flat front was indented and had sideway slits down the bottom.
    Have never seen another again :-(
    Regarding kei and front bar does anyone have a website or FB link? I assume kei is in Japan?
    Cheers
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    #12
    Kei is in Japan. He has an exclusive on most of the products of his kit. Something he's worked out with the mfg/vendors ..
