Cx racing intercooler and radiator kit
WillardJunior Member- 1
I'm currently installing the radiator and I can't figure out how to mount it. If anyone has any experience with the cx racing kit it would help a bunch
Powered by Fund Solvaren. -
NissanEggSenior Member- 5220
Best of luck. They do not offer instructions on how do it nor are they willing to help you out if you try to contact them.
V8srfunSenior Member- 192
FrozenZSenior Member- 584
The CX Racing kit looks like a garbage design, the IC is basically in the worst place possible. You just gotta accept that your intercooler install will be custom. Go front-mount and don't overthink the pipe sizes because unless you're going huge, in which case you shouldn't need this advice, you are going from a 2" turbo outlet to a 54 or maybe 60mm throttle body so there's no point trying to ram 3" IC piping in there. You can either holesaw through the wheel well which makes it a no-brainer, or go over the top of the rad if you have gone with an efan (Even with a big 3-row rad you just have to clip a little bit from the center nose bracket thing to make room for 2" pipe over the rad, and people with smaller rads can get 2.5" over there.)
