link3724 link3725 link3726 link3727 link3728 link3729 link3730 link3731 link3732 link3733 link3734 link3735 link3736 link3737 link3738 link3739 link3740 link3741 link3742 link3743 link3744 link3745 link3746 link3747 link3748 link3749 link3750 link3751 link3752 link3753 link3754 link3755 link3756 link3757 link3758 link3759 link3760 link3761 link3762 link3763 link3764 link3765 link3766 link3767 link3768 link3769 link3770 link3771 link3772 link3773 link3774 link3775 link3776 link3777 link3778 link3779 link3780 link3781 link3782 link3783 link3784 link3785 link3786 link3787 link3788 link3789 link3790 link3791 link3792 link3793 link3794 link3795 link3796 link3797 link3798 link3799 link3800 link3801 link3802 link3803 link3804 link3805 link3806 link3807 link3808 link3809 link3810 link3811 link3812 link3813 link3814 link3815 link3816 link3817 link3818 link3819 link3820 link3821 link3822 link3823 link3824 link3825 link3826 link3827 link3828 link3829 link3830 link3831 link3832 link3833 link3834 link3835 link3836 link3837 link3838 link3839 link3840 link3841 link3842 link3843 link3844 link3845 link3846 link3847 link3848 link3849 link3850 link3851 link3852 link3853 link3854 link3855 link3856
How to 14.7 SLC Pure Plus
  • shromy
    shromy
    • 2189
    http://www.acadianasportscars.com/writeup/writeup1.htm
    I recently purchased a SLC Pure Plus from Zack (Acadiana Sports Car Orphanage). Finally got it functionally installed and testing. Still yet to setup the optional in/out-puts but plan to add them to the writeup as I get there. Figured I would put this out there for some of you interested in the product. This is how I chose to install mine and is by no means the best way to install it for your liking. I am still awaiting the latest NIStune update to include full compatibility for the AFR and aux input. It has been confirmed to work on Matt's side.
    http://forum.nistune.com/viewtopic.php?f=18&t=1584
    My little part to help out. Any questions feel free to ask.
    A short video of it in action.
    http://www.youtube.com/watch?v=84C2ISOcCgM[/video]]
    Hmmm, Whats next?
    84ZXT
  • shromy
    shromy
    • 2189
    Re: How to>> 14.7 SLC Pure Plus
    Got RPM input working tonight, have yet to test in NIStune. I connected the RPM input from the drivers side at connector 3I, pin 17, yellow wire, (88SS) may be same for others with needle type dash. Now just to wire up the MAP sensor I have and try to find a voltage scale for it.
    Hmmm, Whats next?
    84ZXT
  • shromy
    shromy
    • 2189
    Finally found a reference chart for the MAP sensors laying around here, so look forward to seeing some more info on it to come.
    Hmmm, Whats next?
    84ZXT
  • adamvann3
    adamvann3
    • 4160
    Good write-up minus the tapping into the fuse for power. I would rather see an inline fuse off a different power source.
    Good reference for the RPM input, will be using it for my Greddy E01.
    86na - BlueZ
    85t - Mr Tickles
  • shromy
    shromy
    • 2189
    #5
    Does have inline fuses, and that is tapped on the 12v input of the fuse basicly the same as a wire. I somewhat agree with you though I have never had an issue doing it that way, if it was a large amp draw I wouldnt have put it there. I do belive I stated it can be taken from nearly anywhere but chose to use that spot since most guys out there are not to up on tracing down what they need in a harness for some reason. Thanks for the kind words, hope the signal tap works well for you.
    Hmmm, Whats next?
    84ZXT
