How to: Install a 240sx short throw shifter in a FS5R30A
Due to the inevitable instability of using image hosts, this was created in Word, printed in PDF format and is shared via Google docs here:
https://drive.google.com/open?id=0Bx…l9vVE9hdnFpZFE
If you are unable to view or download the file (it's a PDF document) send me a PM with your email address and i'll email you a copy.Last edited by Z_Karma; 09-28-2018, 10:46 AM.
reddzxSenior Citizen- 6440
link says no preview available
1991 Hard-body 2WD
amrebootBanned- 9875
Download it instead of viewing it in Google
That is awesome!
Such a great write up!
Question though.
And excuse my ignorance, but does a short throw shifter generally lower the height of the shifter itself?
It seems that your new one is the same (or near) height of the stock.
Either way, awesome!
The only thing I recommend for all those who does this is to get a new bushing for the ball instead of re-using the old one.
https://fund-solvaren.com. -
Short throw shifters generally don't lower the height any, they merely change the pivot point to make the throws shorter.amreboot wrote: Download it instead of viewing it in Google
That is awesome!
Question though.
The only thing I recommend for all those who does this is to get a new bushing for the ball instead of re-using the old one.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
adamvann3Senior Member- 4160
I prefer it raised even higher
and still much shorter throw than stock86na - BlueZ
85t - Mr Tickles -
HeimdahlMember- 98
AceJunior Member- 4
shromySenior Member- 2189
shane4585Junior Member- 19
MADMIKESenior Member- 1533
Do we know if they make a solid bushing that can replace the plastic on the bottom plastic bushingDD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
you can make one out of bronze bushings if you want to.
my striker arm is different, so im not sure if it will work for the regular 30A -
I scored a Short Shifter off of Benedict"s part-out but I have not really looked into it yet.DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
You would need an aluminum or brass/bronze cup machined with the proper OD to fit in the yoke and
proper ID to fit over the pivot ball, perhaps with a internal snap ring to keep it from falling off.
Z31 30A bushing on left, 240sx short throw kit bushing on right
The ball end measures 12mm diameter, i don't have the ID measurement of the yoke.
ParkerSenior Member- 966
Thanks for the write-up! It's my favorite kind: entertaining AND informative. :-DZoey - 1987 Z31T GLL - HKS EVC / CM SS 3" turbo-back / Stance GR+
I designed it, ergo'd it to my feel, and weighted it identical to my earlier setup except shift the center of weight higher. It's in combination use to my modified fidanza short shifter.shane4585 wrote: who did u have make this shifter extension? please give me a phone number or some contact info
Long story short, it isnt a simple plug and play and will probably not work for you.86na - BlueZ
85t - Mr Tickles
