Upgrade to PRW-2 Ign. Control Module (Power Transistor Unit)
862sikSenior Member- 2159
Re: Upgrade to PRW-2 Ign. Control Module (Power Transistor U
[quote]michaelp wrote: [quote=862sik]Really…mine "looks" like thatOriginally posted by KingmanIz good shit man. That's the TBI Pathfinder style PTU. I may stick a PRW2 on my Pathfinder even though I don't have it anymore just to see if the sliiiiiight surge goes away.
The kouki z31 had the same style.
No it doesnt…it looks the same, on the transistor, but the wiring setup is completely different…and its all wired in with the coil too. My TBI Pulsar has the same crap. The Kouki's is still wired exactly the same as the zenki z31.My Build Thread -
amrebootBanned- 9875
Here is my setup.
Its a complete assembly setup from a M30 including the black plastic cover.
The transistor is the PWR-2
manrossdamnSenior Member- 1153
Alright! I had gotten one from the junkyard a few weeks back thinking it was bad.
Got bored and tried again, works!
Noticed from the start, much peppier, quicker revs and smoother idle. Still has a miss and pop every once in a while. Not too bad though.
Is it bad that the bottom of the unit gets warm?
Haven't driven it around to see how much faster she feels yet -
Thats a sweet setup, I was looking at my M30 and admiring the cover and crap....too bad they're so rare. :-(manrossdamn wrote: Alright! I had gotten one from the junkyard a few weeks back thinking it was bad.
Sometimes the popping at idle is caused by the CAS going bad, too....or the car is running lean (CHTS)
amreboot wrote: Here is my setup.
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
She's probably running rich.
Will do both of those sensors once I get the funds for timing belt/water pump and what not.
Rich doesn't cause the popping at idle…lean does.manrossdamn wrote: She's probably running rich.
If I see another M30 and the junk yard, I will let you know.michaelp wrote: Thats a sweet setup, I was looking at my M30 and admiring the cover and crap....too bad they're so rare. :-( -
silvertonJunior Member- 29
This is what my power transistor set up is, I'm just going to assume that this PWR module is not a viable upgrade without modifying the chassis harness?1987 Nissan 200sx SE V6 - daily
1995 Nissan Pathfinder SE - wheeler
-Dennis -
Sharpen047Senior Member- 507
or an adapter harness can be made.silverton wrote:
This is what my power transistor set up is, I'm just going to assume that this PWR module is not a viable upgrade without modifying the chassis harness? -
I just did this modification. I made a small adapter harness just incase for some reason my prw goes out and I cant find another one. I can always go back to my factory one if I had to.
At idle I didnt notice much, maybe a slightly smoother idle. I revved it a bit, seemed a little more peppy. But when I drove it, it did rev much faster as I granny shifted through the gears. Pickup was much nicer and smoother. I used to have a small hickup around 2200 rpms but thats gone now. It feels as if im not making the car work as hard as before when really getting on it.
In all, it was definitly worth it. Definitly.My Build Thread -
[quote]Sharpen047 wrote:Is there a write up on how to go about that?Originally posted by silverton
This is what my power transistor set up is, I'm just going to assume that this PWR module is not a viable upgrade without modifying the chassis harness?or an adapter harness can be made.1987 Nissan 200sx SE V6 - daily
-Dennis -
[quote]silverton wrote: [quote=Sharpen047]Doubtful. Buy me a S12 and I'll make a writeup for you. :nanan?reOriginally posted by silverton
Nothing in this thread applies to the S12 because as far as I am concerned until I get my hands on one, they are completely different.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Lol
I'll make a mount once I get the motor back in and running.
2001 Mazda Miata LS
also a 1989 Nissan 240SX
I used the mount from the maxima. Bent the little tab and bolted it where the factory one went. I was going to make something nicer, but oh well lol.My Build Thread
