Auto to manual brake pedal
I cut mine because I was lazy and on a tight schedule. Shaved the edges and fit the rubber boot from my MT pedal over it.
Works like a damn charm.
2001 Mazda Miata LS
also a 1989 Nissan 240SX
Also known as half steppin. That's how you treat a "ho" get it?Kimbro Slice;341689 wrote: I cut mine because I was lazy and on a tight schedule. Shaved the edges and fit the rubber boot from my MT pedal over it.
Works like a damn charm.Cha iro
^Call 'em up so you can lay some pipe then send them on their merry way?
2001 Mazda Miata LS
TempastSenior Member- 133
Clutch pedal was in less than 2 minutes after the brake pedal. I don't know why the brake was so difficult. But that stuffs in, now I have to adjust the brake pedal. The car looks funny with an auto trans and a clutch pedal :P1986 300ZX factory Turbo 2+2 5 speed swap. 1985 Toyota MR2. Floor boards gone. Good fabrication practice.
Would be funnier if you hooked up the clutch pedal to the rear brakes and the main only to the front brakes… then you can bias your stopping power on the fly like rally cars
That would be kinda funny. Though it would make burnouts a lot easier with an automatic!1986 300ZX factory Turbo 2+2 5 speed swap. 1985 Toyota MR2. Floor boards gone. Good fabrication practice.
