Rust is fun. Rear crossmember mounts GONE!!!
 akurtzer57Senior Member akurtzer57Senior Member- 205
 Rust is fun. Rear crossmember mounts GONE!!!Fun begins. Tore interior out and this is it. I temp fixed the rear crossmember bolts a year ago just felt safer moving it around since they werent even attached. Drives side isn't as bad as passenger. Pasenger goes alll way up to ecu area. Will be cutting sections out of another car later today. Will update later next week.
 sgtpepper67Member sgtpepper67Member- 58
 Ooo, looks like soo much fun. I can wait to have to do the same repair to my car.
 I hope you take pictures through out the process.
 Will be taking loads of pics charging camera so won't have cell phone pics. Will also be doing inside wheel wells and some lower quarter repair. Need to check out A pillars not sure on those Don't apear to have any but never know.
 862sikSenior Member 862sikSenior Member- 2159
 Im glad we have no rust here in california :-) but we do have the smog tree huggers here :-?
 Good luck man, may the force be with you :-DMy Build Thread
 Just so you know, those arent the rear crossmember mounts…just for alignment purposes.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
