bixenon Projector Retrofit. **kouki retro in progress**
Sharpen047Senior Member
- 507
862sikSenior Member
- 2159
Sharpen047 wrote: I put projectors in stock lights. No halogen.
Me personally I like a little bit of "style" and contrast. Just being black doesnt look right IMO. You can maint your housing black, and leave the shroud chrome. There are endless possibilities.
Today I will be painting it black, but I want to try and get started on the lens cover. Hopefully it turns out good.My Build Thread -
862sikSenior Member
- 2159
I love satin black paint! I also painted the sides of the shroud to look more like a floating shroud.My Build Thread -
edicer2Ant Eater
- 2262
looking good!! interested in see how the acrylic comes out.86 NA
87 Turbo
bettzysdaddySenior Member
- 108
Re: 7x6 bixenon Projector Retrofit. **Prototype #2 on page
862sik wrote: Unit put together. I finally bought some low gloss paint instead of gloss, looks much better. These units had city lights, I took them out and routed the wiring for the high beam through them. I also like these housings because they have built in vents, saves me troubles later.
Now this will definitly fit in the z lol. -
862sikSenior Member
- 2159
Magic!
lol. I used a water that basically sandwiches the projector and the headlight together. It comes with the projector when you purchase it from the company.My Build Thread -
DeleriousZSenior Member
- 6874
So when are direct replacement housings for the kouki going to be available?
1990 jetta vr6'd -
862sikSenior Member
- 2159
DeleriousZ wrote: So when are direct replacement housings for the kouki going to be available?
As for replacment housings being avalible, I can always start them as long as I get a down payment for supplies…possibly a set of housings if you have them, if not I have to go to the yard and pull them myself.My Build Thread -
VenSenior Member
- 510
Probably something like this
862sikSenior Member
- 2159
[quote]Ven wrote:Originally posted by 862sik
I assume this is the kouki shroud right? If you want to be fancy, you could fit a nice thin white led strip across the top of the shroud so when the lights are down people could flip the leds on (maybe wired to the foglight switch). I'd think it'd look cool.
My Build Thread -
VenSenior Member
- 510
[quote]862sik wrote: [quote=Ven]Originally posted by 862sik
Thanks for the suggestion. If the person who is buying it wants it....then I will do it. I personally don't like them, but these are not my lights hah -
RocklinMike300zxSenior Member
- 276
That is a really good idea though. I could see perhaps modifying the headlight bucket or something to fit in some LED strips and have them wired to the foglights or use a custom switch to turn them on when the buckets are down. Maybe I'll talk to my buddy about making something to that effect. -
862sikSenior Member
- 2159
RocklinMike300zx wrote: That is a really good idea though. I could see perhaps modifying the headlight bucket or something to fit in some LED strips and have them wired to the foglights or use a custom switch to turn them on when the buckets are down. Maybe I'll talk to my buddy about making something to that effect.My Build Thread -
862sikSenior Member
- 2159
Well I finally had time to put together these lenses and let them dry (after countless failed trials). I SHOUld of made them maybe a 1/8 higher to take up the gap in the top and bottom, but I dont think it will affect anything. I also decided to router the edges just a little bit to make it look better. I think it looks great. It mimics the factory glass. I will probably push the whole lens upwards so that there wont be much gap up top.
If I decide to, I may paint the inner side of this lens black to further cover everything. After im done ill flame polish the corners to get rid of that "white opaqe" look where the lens meets eachother.
Tell me what you guys think
My Build Thread -
edicer2Ant Eater
- 2262
Looks fantastic man! Will that fit between the bumper looks like it sticks our really far but i guess i havent looked at the factory headlights to see how large the glass part is.86 NA
87 Turbo
