Help with 86 spoiler
  • Xpress
    Xpress
    Junior Member
    • 17
    I've got a 87 model and while at a salvage yard I found a 86 with a perfectly good spoiler. I removed the spoiler along with the third brake light and the rear wiper arm. I like the way the 86 wiper arm looks and would like to use the spoiler on the car. The problem is how to fill in the space for the third brake light. I thought about using the brake light for the spoiler but I really like the high mounted light on the 87 and want to stick with that.
    It looks like the spoiler is made of abs plastic and I'm wondering if it would be possible to attach some type of support inside the opening and the use fiberglass to fill in the opening. Will fiberglass even adhere to the plastic or would it be better to cut some abs plastic and use a strong cement and use a filler to smooth out. I hate to sound dumb but I've never tried fabricating something like this and i'm hoping someone here may have done something like this before.
  • Axel kain
    Axel kain
    Moderator
    • 1221
    I'd say make a filler piece, and epoxy it in, then fill/smooth in and paint. fiberglass will likely not want to stay/hold shape to it.
    sigpic
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    I've seen them filled in before but I didn't get a description of how it was done
    1991 Hard-body 2WD
  • zxracer
    zxracer
    • 135
    Or you can integrate another light into it.
    I picked up the same spoiler for my 88 due to the looks and eventually will add a light that glows 300zx or Nissan in it. In the meantime, I left it till I can get to it and it doesn't look intrusive at all.
    1988 Nissan 300zx (Improving it one day at a time)
