Are 350z steering wheel splines compatible?
G-EJunior Member
- 6320
Looking at the nrg catalog, and the g35/z33 wheels hubs have a protruding splined section, this would work well to clear the plastic cowling on the z31 if it's able to mate up… anyone know? -
G-EJunior Member
- 6320
adamvann3Senior Member
- 4160
My s13 hub cleared my plastic cowling. Very slight rubbing* but not enough to make me think twice.86na - BlueZ
85t - Mr Tickles -
newsieoneSenior Member
- 120
G-EJunior Member
- 6320
newsieone;349442 wrote: No prob with my Momo hub and wheel.
86na
88t -
- 120
No, it is specific to the Z31. I just checked the Momo site and the adapter for a 350Z is part #3516. This adapter, as well as other aftermarket hubs convert to 6 bolt wheels. They all appear to be usable for Momo, Sparco, Nardi, etc.
FYI for the Z31 crowd: the Momo hub adapter for 84-89 is part #3507.
86na w/Momo Combat wheel, Combat Evo shift
88t -
inqui-Z-torSenior Member
- 9020
I hope this isn't considered a thread hi-jack nor an intrusion. If so, it is NOT the intent.
But … don't 350Z steering wheels have an "air bag"?
IF and G-E didn't indicate nor imply that this was the intent of his original post.
What are the ramifications (things to consider - electrical connections, air bag, etc … ) if one were to "fit" a 350z steering wheel onto/into a z31?'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
G-EJunior Member
- 6320
inqui-Z-tor;349487 wrote: I hope this isn't considered a thread hi-jack nor an intrusion. If so, it is NOT the intent.
What are the ramifications (things to consider - electrical connections, air bag, etc … ) if one were to "fit" a 350z steering wheel onto/into a z31? -
jaqattack02Senior Member
- 1185
What are the ramifications (things to consider - electrical connections, air bag, etc … ) if one were to "fit" a 350z steering wheel onto/into a z31?Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
- 9020
G-E;349512 wrote: In most jurisdictions you aren't allowed to modify the safety devices in your car, so you can't legally remove an airbag… but people still do it anyway
Anyway .. I was concerned over the possible effects of an "active" airbag system being installed on a car that didn't orginally have an airbag system? I guess you aren't technically modifying the safety system of the z31 (since it didn't have one) .. but could be risking injury by having it?? This presumes you could satisfactorily install the steering wheel in the 1st place.'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
reddzxSenior Citizen
- 6440
Aren't there enough attractive steering wheel options already for the Z31 without have to jury rig a 350Z steering wheel?
1991 Hard-body 2WD
G-EJunior Member
- 6320
Jury rig? You must be thinking of a redneck who loves jb weld and ducktape… I'm trying to mate things properly with science and shit
But it's alright, no one seems to know -
- 4160
What the thread discussion was suppose to be around was aftermarket hubs to run aftermarket steering wheels.
The 350z NRG aftermarket hub has protruding spline, in which hypothetically GE was searching for a solution to clear the plastic shrouding. This aftermarket hub would mount to an aftermarket wheel. I have an s13 aftermarket hub which has very slight rubbing but clears.
When hubs do not clear it looks like this, or people tie bandana around them
Putting a 350z steering wheel in a z31 would look dumb, be heavy and provide no benefit.86na - BlueZ
85t - Mr Tickles -
michaelpSenior Member
- 9384
adamvann3;349528 wrote: What the thread discussion was suppose to be around was aftermarket hubs to run aftermarket steering wheels.
http://z31performance.com/showthread…highlight=vq35- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 120
The Momo adapter has been designed to collapse in the event of an impact, ie. faceplant. The adapter is a steel skeleton that when installed is covered by a round black rubber bellows. The bellows fits between the back of the wheel and the shroud as a finishing piece. No muss, no fuss, easy 15 minute install. Included is electrical contact plate, etc. for center horn button on wheel of choice.
http://www.ebay.com/itm/Momo-Steerin…94e4c1&vxp=mtr
