na2t wiring issue
jm9308Member- 95
na2t wiring issue
Need some help from the community.
Na2t heavy stuff complete. Now when I turn it over it fires and at times barely idles below 500 and or chokes.
When I remove the mafs connector at times its starts and idles below 2k.
With 2 pins jumped at the maf connector it start easily, idles and revs like a charm. See attached pic. I apologize for the small size but it seems this new version of v5 is limited to smaller size pics.
I am at a complete loss.
Tripe checked connections, continuity, sensors, new vacuum lines and relays are good.
I am using 85 n/a harness with 87 ecu and o2 sensor. Installed the turbo idle controls and wired as described on the xenonz31 site.
Thanks Attached files85 NA Daily Driver (Project NA2T)
SS#330 (The Sunday Cruiser)
77 Datsun 620 Pickup -
jm9308Member- 95
Please delete.85 NA Daily Driver (Project NA2T)
