Ignition switch
Augustus MaximusSenior Member
- 1739
Ignition switch
Just how hard is to swap this thing. How do you pull those headless bolts.Cha iro
Z_KarmaAdministrator
- 3318
I used an easy-out to back out the screws on one and just drilled the heads out on another.
Putting a little penetrating lube in there should help them back out.
They're not torqued in there incredibly tight but any thread corrosion can make it a pain in the ass.
I replaced them with some stainless socket head cap screws from ACE hardware, M8 i think is the thread, possibly M6
reddzxSenior Citizen
- 6440
I drill a small eight inch deep hole in them and tap a square drive screw driver in and just turn them out.
1991 Hard-body 2WD
flatfootSenior Member
- 253
I've yet to do one on a nissan.
I've done a few toyotas at work. Just used a die grinder with a cutoff wheel to cut slots in them and used a custom flat screw driver with a wrench attached to it for leverage.
The replacement bolts are break to torque. You just keep tightening them until the heads break off.Life's short
Go fast
Have a blast
Leave a good looking corpse -
- 1739
I grabbed the steering column with switch attached and swapping the column is starting to appear more appealing than drilling out two ignition switches. Thanks guys.Cha iro
Big Slappy ZSenior Member
- 237
you just cut a notch so you can fit a flathead screwdriver in there. They aren't torqued very tight. There's a video/guide somewhere online I remember watching. I didn't swap mine out because I didn't feel like pulling the dash again to get to it.
