Window Corner Trim
sp3cialfxMember- 34
Window Corner Trim
Anyone know where I can get the pictured items without spending an arm and a leg? All the ones I come across at the junk yard are just as dry rotted and broken as the ones on my car currently.
Attached files -
mizagyuSenior Member- 539
nissanparts.cc and use the nissan fast software from xenon to get the part numbers.
expect to spend over $200 for all peices you need.. -
1artworkzSenior Member- 1143
This part is no longer available through Nissan.
http://www.300zxpartsforyou.com/ has them from time to time. Look for them on page 32. Site is slow to load due to the images all being on one page. -
There is a high demand for this item.Cha iro
viscoMember- 63
There has to be an opportunity for fabricating/fixing this part to make some money. Almost all Z's I have seen have rotted mirror triangles. I've use silicone a few times to keep mine from falling apart. Someone has to have injection molding equipment out there -
The question is would one have enough sales to off set the costs of development, molds and production?visco;n767195 wrote: There has to be an opportunity for fabricating/fixing this part to make some money. Almost all Z's I have seen have rotted mirror triangles. I've use silicone a few times to keep mine from falling apart. Someone has to have injection molding equipment out there -
NissanEggSenior Member- 5220
Proudear of Japan makes reproductions of these. They are around $200. They are the only ones I know that you can get them new.
FlyingTSenior Member- 1095
Isn't this what you want? From MSA theZstore.com. $47 each.
http://www.thezstore.com/page/TZS/PR…03c01/8033101P
~~Description:
This seal fits along the back edge of the triangular corner molding. It seals the front edge of the door glass to the corner molding when the window is rolled up. Sold individually, one required per side (2 per car).Restore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
viscoMember- 63
I think the part Flying T is referring too is this one.. http://www.courtesyparts.com/80827-r…-p-141345.html.
There are also 3 parts that go over the window at the mirror. these triangles seal the mirror frame both inside the and outside the car over the window glass. Those are the ones that are impossible to find . The attached pic is the piece that straddles the window Attached files
