Dash replacement electrical Gremlins
Charles84AEJunior Member- 9
I have an 84 50th AE and I replaced my dash with one from an 85 or 86 (can't remember, I've had it awhile). Everything connected fine. I noticed that my combination switches aren't working. When I turn on the lights only the left combination switch (headlight up/down, hazard, cruise control) illuminates and the other side doesn't. My headlights come on but do not raise up (on the down position). I checked the bulbs and relays. Is the wiring harness different from later than 84? I got rid of my old dash but kept the wiring harness. Should I pull the dash again and replace the harness or could it be something else.
Thanks.
Charles (919)423-3286 -
sir420Senior Member- 395
Could be faulty connections. Check and clean all electrical connections. Also clean the combination switch. Dash harnesses should be the same for 85 as an 84.The Herd
85 z31 GLL N/A2T (7psi daily){Totaled 1-24-2012}
85 z31 GL N/A2T slightly modified
85 z31 GLL Turbo Kaminari converted to N/A
85 z31 GLL Turbo (parted out)(scrapped)
90 s13 se n/a (stock)Wife blew up the engine
88 xj40/xj6 (stock) Yard Art
88 Mighty Max
99 WJ 4.7 Limited -
I am also in Fayetteville NC.The Herd
88 Mighty Max
99 WJ 4.7 Limited
