Body/Door Trim Removal
adroitcaptorSenior Member- 178
So is there a way too get this sticky/foam/silicone crap off or a better way to take the trim off? I tried dental floss, a paint scraper, and a body scraper thing after searching and the below is the result (not much difference). FWIW I could care less about the paint as I will eventually repaint it. I do care about the body. http://i270.photobucket.com/albums/j…203_150604.jpg -
FlyingTSenior Member- 1095
Get 3M sticky tape adhesive remover.adroitcaptor;n770967 wrote: So is there a way too get this sticky/foam/silicone crap off or a better way to take the trim off? I tried dental floss, a paint scraper, and a body scraper thing after searching and the below is the result (not much difference). FWIW I could care less about the paint as I will eventually repaint it. I do care about the body. http://i270.photobucket.com/albums/j…203_150604.jpg
http://www.3m.com/product/informatio…oval-Disc.htmlRestore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
Will that take off that capt foam and the silicone? (The Black silicone strip in the middle, is on there like a white stripe on a skunk.) -
When i removed mine, i used goo-gone and a razorblade(s).
Then i discovered the existence of this:
http://www.autogeek.net/3m-stripe-off-wheel-07498.html
and it worked beautifully, like a pencil eraser on steroids.
I wish i had discovered it before i fucked up my clearcoat with the razorblades.
utjonSenior Member- 260
I used a heat gun to take the trim off but the remaining stuff was totally annoying. I should have done dental floss to get it off with the trim. It took eons with goo gone/wd40/etc. So i bought that wheel and it did all of jack for me. I bought plastic razor blades on amazon.. Best creation ever, no paint damage at all.
Side question.. Anyone know how much shops charge to fill the holes on the 86?Daily:
09 2.5SL Altima Grey
08 4.0SE Pathfinder 4x4 Grey
11 Ducati Diavel Carbon Red
Z31s:
88t Grey
86t Pewter
