Fuel Gauge, trip meter problems.
wasgoodJunior Member- 17
Hello, I have an Australian 1985 digital dash Z31, and the trip meter doesn't light up anymore, the fuel guage will always read under 4 liters. I believe the sensor is faulty, but I don't know if it's related to the trip meter at all.
Basically i don't know if the two issues could be related, and it might not be the sensor. -
Its probably the sensor. The dashes are known for failed solder joints causing dead sections and the fuel sending units are known to fail.5.3 LSx Z31 -
It's not a dead section, the test seems to work fine. But I guess what I'm asking is it the sensor causing the trip meter to go out as well? -
FlyingTSenior Member- 1095
The fuel sensor has nothing to do with the trip meter. Almost all US Z31s have had to replace the fuel sensor, both analog and digital. The replacements have a different, more robust design.
Even today, my US 85T gauge will go about 1 inch above full when I fill the tank to 1 inch below empty when I have around 1/2 a tank left. I know when it says empty I have about 1/2 a tank left. And if I want to push it, the 1/4 tank gauge and everything else (lights, bells, Betty) still works warning me when I was really getting low. In my case the way it works, it is a minor inconvenience. But it freaks passengers out when they look and see the needle way below empty. Not many cars have dual fuel gauges.
But I don't believe the digital dash has dual fuel gauges.Restore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
