fender cutting advice needed
adroitcaptorSenior Member- 178
ATM I am super high on ST springs (wheel gap for days). I have a Z32 NA subframe and coilovers to come. I need advice from ppl running low body and wide tires plz. (Right now running 17x9.5 square but thinking about 18x11 RPF1s).
I flared the fender lip out instead of in. Then I cut above the pinch weld separating the outer 1/4 panel and the inner wheel well. After working the flare out I had to 'pie cut' the inner wheel well lip as I could not stretch the metal far enough to meet the inside 1/4 panel (now flared). I think I moved the wheel well up about an inch and a half…
My 2 questions:
Do you think this will be enough clearance inside the whel well?
Shoule I cut and flatten that hump on the outside upper part of the wheel well?
thx! -
862sikSenior Member- 2159
adamvann3Senior Member- 4160
Well considering there is no identification if your care is a zenki or kouki nor front or rear fenders it is pretty hard to suggest anything.86na - BlueZ
85t - Mr Tickles -
reddzxSenior Citizen- 6440
Sounds like it was the rear on a kouki
1991 Hard-body 2WD
If thats the case then 18x11 fit without any issues under rear stock kouki fenders86na - BlueZ
85t - Mr Tickles
