Shaved engine bays, anyone?
floridaZSenior Member- 2781
Damn that white one is a sick looking motherfucker. I don't think it's possible to get a Z31 that clean with a VG though.Feedback- viewtopic.php?f=18&t=19840
Ford FalconJunior Member- 25
Right on. It may be a pain, but it'll be a learning process. I intend to relocate whatever I can out of the engine bay.... battery, relay box, etc. At least by making a custom harness, I'll have the right length wires to tuck away in the right places, with the right connectors. I'm also using a VH45 engine instead of the stock VG, so this has to happen.OK85ZX wrote: I've been working on plans for building a new harness for a while. It may be a large task but given the things that can be done with it, I consider it a worthwhile project (and in most cases a better solution than adding 25+ solder joints to extend old/hard wiring). Those mil connectors are sick and I would love to use them myself for the firewall connection… but I don't know anyone who has the crimpers needed and I don't plan on spending $150+ on connector crimpers.
as jn1cz said, there are a few wires that run through ugly places regardless of a fender tuck or not… the only way to combat this sometimes is to move the location of the wire destination… like the relay box, etc.My Project '88 Z31 To Do List:
S13 rear subframe,
'91 Q45 R200 diff,
'91 Infiniti VH45DE,
Z33 6-speed transmission
Custom wire harness
vagabondSenior Member- 3455
reddzxSenior Citizen- 6440
+1vagabond wrote: Do you have the VH yet or are day dreaming?
1991 Hard-body 2WD
I used to dream about it, but it's now becoming a reality. I started it in '05, slowly acquiring stuff as I've been able to afford it. I already have the VH torn down. I took it from a '90 Q45. I also know someone who has completed the swap, but I'm taking it a couple of steps further.vagabond wrote: Do you have the VH yet or are day dreaming?My Project '88 Z31 To Do List:
S13 rear subframe,
'91 Q45 R200 diff,
Custom wire harness
zachheldtMember- 65
im trying to get a wire schematic drawn up for the engine bay i really like the look of that mil connector though you could clean up an engine bay really nice with one of those. i think that if someone took the time they could make a VG as clean as the wolfsburg jetta. its just what level you wish to mod to.
