Steering wheel size
  • 300zxturboftw
    300zxturboftw
    • 3709
    Steering wheel size
    Looking to upgrade the steering wheel. Unfortunately I'm an hour away from the car and can't get to it sooner than I want. Does someone have measurements of the stock steering wheel? I'm debating between 330mm and 350mm, but I'm on manual steering, so most likely will do 350mm. Just want to confirm how much smaller it is.
  • Pace
    Pace
    Moderator
    • 1108
    Confirmed: GLL wheel measure's 15" diameter. 350mm is going to be the closest to that in common size aftermarket wheels.
    '86 300ZXT GLL
    '78 Datsun 280Z BP
    '11 Saab 9-3 Aero XWD
  • 88sinZ
    88sinZ
    • 2019
    88 GL is 15" (~380mm)
  • mtherkamp
    mtherkamp
    • 243
    I run a 330 with manual steering on my 88, I like that its smaller, it makes it easier to get in and out of the car. Also I like how quick I can flick the wheel in a corner. It is a bit of a pain to park, I don't ever parallel park it, lol!
    Butter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard."
  • 300zxturboftw
    300zxturboftw
    • 3709
    #5
    Thank you. So basically 8.1% or 13.4% smaller. With a 330mm is the dash still easy to see everything or is speedo/rpm and such blocked off?
  • mtherkamp
    mtherkamp
    • 243
    #6
    There is a little bit of the speedo obstructed, but its not much at all, depending on how tall you are, where the seat is, and how low you like the wheel. YMMV of course, if you were in the area I'd def let you try it out, but southern IN is kind of a car-culture hole with not much of a scene.
  • 88sinZ
    88sinZ
    • 2019
    #7
    bro, you got wheel adjustment tho
