zenki "300zx" Third Brake Light
jy1235689Member- 59
So following the instruction here: http://www.xenonzcar.com/z31/Illuminated300zxbar.html
**USE A HEAT GUN. A hair drier, as you can see on mine, didn't work getting the glue free.
With the following changes:
1) use LED strips. I got a cheapo set off the web for $5 shipped using 5050 smd leds
2) four strips will fit behind the 300zx logo
3) wire 2 per hot wire (running + brake)
Powered by Fund Solvaren.A twist on xenonZcar's "300ZX" indicatorLast edited by jy1235689; 09-01-2019, 11:55 PM.1984 GLL 300ZX NA to VG30ET Engine Swap Big Turbo
1987 Auto Rare Kouki Slicktop Velvet-Cake (NA2T in progress: parts sourced)
- 1 like
Pretty neat.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
2003 Nissan frontier D22 supercharded vg33e 4x4
- 1 like
