Door panels??
Hatchbaby88Member- 50
Door panels??
I am replacing the vinyl on the door panels with red and black as seen, but the adhesive glue I am using isn't securing the edges. Does anyone have any suggestions that might work? Thank you -
vagabondSenior Member- 3455
3M, spray both panel and trim then adhere and weigh down.
However I hope it does not work out for you as that looks horrible.
JMO
Guest
me plus glue never works out well. yeah spray both items and be carefull once its on there its on there for good. i personally don't like the look. its not bad just to much contrast for me. -
NismofreakMember- 80
Contact CEMENT. Real contact cement.
Put some on the back side of the material and more on the panel, LET IT TACK FIRST, then line it up, press it on and roll/smooth the air bubbles out.'87T -
hey how hard is it to redo the door panels…just curious i kinda wanna do it to my Z…
1988 570zx SS Edition
Steve88tSenior Member- 1337
"I glued myself to.....myself"
The "real contact cement" idea is what you need here. Spray both surfaces and let it tack up a bit before joining. Then make sure it is clamped or weighed down to hold in place. All edges should wrap around the corner to the backside to prevent it from getting snagged and pulled up.http://z31performance.com/forum/viewtopic.php?f=5&t=147 -
floridaZSenior Member- 2781
Just out of curiosity, did you remove the center piece and replace it with the vinyl, or did you glue the vinyl over it? If you removed it, how did you do it?Feedback- viewtopic.php?f=18&t=19840
reddzxSenior Citizen- 6440
3M make a couple grades of spray adhesive. Get the 77 type. Use some long pieces of 1"x1/4" wood material on each side and use clamps
1991 Hard-body 2WD
Thank you all for the in put. I went and bought some contact cement today, so I will be finishing up saturday.
I removed the material from the middle. It was easy use a thin razor around the edges. All the way around, no missing little spots. and then peel off. -
ShamWowSenior Member- 1905
Are we talking about the door panel insert here?
Instructions:
Remove door panel.
Flip over.
bend tabs on back of insert so they are vertical.
flip over.
Pull off insert.
Am I way off here?"produce first.talk second." -
I was just thinking about that. Yes, do what Mike said.
Chris86NA2TSenior Member- 837
not way off at all.. that should be pretty obvious to a non-retard who removes a door panel. pop that piece out, peel off the old shit, install the new material so it wraps around the backside, glue and reinstall. i did this years ago to resecure the stock leather piece.Mike_GruiZinga wrote: Are we talking about the door panel insert here?
Instructions:
Remove door panel.
Flip over.
flip over.
Pull off insert.
Am I way off here? -
where do you guys buy your materials…i kinda wanna redo mine in tweed because i hate leather
Well, ZPoorinFL took his door panel to a guy local to have it recovered. The guy then said that it was impossible because of that center piece. Ever since then I've been trying to figure out why the hell he would have said that.Feedback- viewtopic.php?f=18&t=19840
