OEM hood scoop hole locations
SATANSenior Member- 6782
I did a little searching for the OEM hood scoop hole location but couldn't seem to find anything. I going to put the the hood scoop on boostedmammas AE soon but need to know the proper location of the holes.
If I do not get a reply with the proper dimensions or a link to the proper dimensions, then I will just go measure my 85t and post up what I come up with.85 Z31 6.0 LSX turbo 766whp/792wtq
Guest -
Theres a little indented part in the underhood insulation in the approx. spot where it should be…- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
onefast87Senior Member- 696
hope this helps. i saved it so i could do a hood scoop to my NA.
http://www.youtube.com/user/onefast87 -
That is damn near exactly what I measured out off of my 85T hood.onefast87 wrote: hope this helps. i saved it so i could do a hood scoop to my NA.
Thanks man.85 Z31 6.0 LSX turbo 766whp/792wtq
SpazzymcgeeSenior Member- 108
xenonxiiiSenior Member- 437
Does anyone have the Bolt hole size off hand? I am adding this to xenonzcar.com as a write-up as as I don't have a scoop available to measure.
