We have determined that a 350Z clutch works in a Z31 right?
  • Gregmatic
    Gregmatic
    • 2193
    Just verifying as I picked up a new aftermarket 350Z PP & disc. Hopefully it fits, as I saw it as an option on one of DXD setups.
  • NissanXRMA
    NissanXRMA
    • 3245
    Yes.
  • SATAN
    SATAN
    • 6782
    It works on the 240mm flywheel, not the 250mm flywheel… I think.
  • Dave@SBC
    Dave@SBC
    • 494
    The OE 87-89 turbo flywheel have a pressure plate drill pattern all it's own. The 350z pp has the same drill pattern as the 84-89 n/a and the 84-86 turbo. Also. The 350z flywheel is flat and the 300zx is stepped. That has to be addressed. Not doing so could result in an extremely low engagement or possibly a release issue.
    Dave
    Z31P sponsor
    800-988-4345 ext: 114
    http://www.DXDRacingclutches.com
    90 Z32 Base 5spd, 05 Z33 Touring 6spd.
    SOLD- 84 Z31 NA2T GLL 5spd
  • MADMIKE
    MADMIKE
    • 1533
    #5
    Is there any option for the 30a crowd? Maybe with this new cromoly biz?
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • Careless
    Careless
    • 13279
    #6
    MADMIKE wrote: Is there any option for the 30a crowd? Maybe with this new cromoly biz?
    it bolts up to the fidanza. its not the trans that is the issue, it's the flywheel.
    any aftermarket flywheel that works in both the 71C and 30A should work fine.
    I literally just checked the dowel pin and bolt holes 20 minutes ago.
  • DeleriousZ
    DeleriousZ
    • 6874
    #7
    Can use the 240mm flywheel with a 30a if you please.
    1990 jetta vr6'd
  • Durkin
    Durkin
    • 513
    #8
    ^^ I have an 85t in my shiro using a 30a, no problems with that. can you put a 240mm on a W series turbo? or will the starter not engage it?
    SS #341
    "This car can be vicious, but in an unusual way, like a shark in a funny hat."
    -Jeremy Clarkson
  • FlawleZ
    FlawleZ
    • 1971
    #9
    Chromoly or just pick up the 240mm flywheel.
    545 RWHP & 540 RWTQ
  • Careless
    Careless
    • 13279
    #10
    or Fidanza.
    But had I not already bought one last year, I would be buying the Chromoly SBC.
    I just got back from having my Fidanza resurfaced a hair's width, with a wet-stone resurfacing tool as Dave @ SBC suggested.
    The sintered steel friction plate was quite scorched from repetitive slipping and transmission shudder in order to keep my drivetrain together.
    That's about the most you can resurface an aluminum flywheel and steel plate without having to replace the friction disc. The inside fasteners that hold the plate on were juuuuuuuuuuuuuust brushed with the resurfacing stone, so that's it for this unit.
    If I'm ever going to pull the trans again, I may just get a Chromoly flywheel if they're still available in the future. I think SBC will sell enough of these to warrant keeping a supply in stock.
  • Rick88ss
    Rick88ss
    • 2433
    #11
    Durkin wrote: ^^ I have an 85t in my shiro using a 30a, no problems with that. can you put a 240mm on a W series turbo? or will the starter not engage it?
    What flywheel and clutch do you have in there now?
    Shiro #443
  • FlawleZ
    FlawleZ
    • 1971
    #12
    You can use either the 240mm or 250mm on any transmission and any engine and any starter. Only the clutch/pressure plate assy and flywheel have to match.
    545 RWHP & 540 RWTQ
  • MADMIKE
    MADMIKE
    • 1533
    #13
    oh, I thought that there was an advantage to running the 250mm Flywheel.
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • Durkin
    Durkin
    • 513
    #14
    Rick88ss wrote: What flywheel and clutch do you have in there now?
    As far as I know its a factory turbo clutch made for the 85t. It was on it when I got the engine, with only about 300miles on it.
    SS #341
    -Jeremy Clarkson
  • Rick88ss
    Rick88ss
    • 2433
    #15
    [quote]Durkin wrote:
    Originally posted by Rick88ss
    What flywheel and clutch do you have in there now?As far as I know its a factory turbo clutch made for the 85t. It was on it when I got the engine, with only about 300miles on it.
    If it's stock 85T parts then the 240mm flywheel works with the 30A 5 speed.
    Shiro #443
