Pathfinder 30A
comrade_charlieBanned- 355
I have a 2wd 30a out of a 2door vg30 pathfinder sitting in my building if anyone wants measurements or if someone wants me to mount it to a vg30 I have laying around -
Geoffs89PathyMember- 80
Zombee_XXXMember- 78
[quote]FlawleZ wrote:Wd21(95 and earlier) pathy got the 30A alsoOriginally posted by sporkliftNot to thread jack, but which pathys came with 30A? No z31t's anywhere near here, but many pathys.
I believe all the VG33 powered Pathfinders/Frontiers/Xterras came with the 30A. Also i'm pretty sure some of the VG30 Hardbodys could come with the FS5R30A as well.
Anyone know the difference between the FS5R30A and FS5R30B transmissions?~Zzz~ 85 300zxt 180k ~ 92 pathy 140k
http://s592.photobucket.com/albums/tt10/Zombee_XXX/
Originally posted by sw150Welcome. Sorry your in York. I have family there and get there often. I just got done telling Matt it's like the arm pit of Ne.Originally posted by slaman operating system must operate - sidux.com -
rb26powered74zcarJunior Member- 6
nismopuAdministrator- 2221
If you follow the z32 install guide it will be the same for the pathy r30a. They're the same length and the mount is in the same location."Its the s12's sexy over weight step daughter, the z31" -
stprasinzSenior Member- 300
Shifter is gonna be 4" off.... But drive shaft needs 4" longer.... I just may find myself a different intake (ala pathfinder, that I have sitting right here), and us ethe headers I just bought And slide the engine back 4 inches.... then until I do the s13 rear swap I could use the factory shaft too..... :twisted: I think I may like the end result..... -
HairyballsMember- 50
the hardbody KA24 71C is in fact a WEAKER! transmission and the dimensions
Overall length: 30.5"
Bellhousing to center of trans crossmember bolt hole: 22"
Bellhousing to shifter plate: 22"
the 71C is 36" long.
1986 300ZX GLL auto non turbo -
FlawleZSenior Member- 1971
Which parts specifically are weaker?Hairyballs;346906 wrote: the hardbody KA24 71C is in fact a WEAKER! transmission and the dimensions
545 RWHP & 540 RWTQOriginally posted by Andrew84zx
This thread is about the 30A, though. And its well known that the newer *240SX* 71Cs are stronger…as for the Hardbody 71C, it wouldn't surprise me if it were the same. How did you determine its weaker by dimensions?Hairyballs;346906 wrote: the hardbody KA24 71C is in fact a WEAKER! transmission and the dimensions
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
slammedfcSenior Member- 288
So you mean i dont have to pay "exotic japanese car" tax on a 30a now? Thank god.... My 71c has the infamous second gear grind so bad i'm certain my "used to be clean internally" gearbox has metal shavings in the penzoil now.... I'll give this a go. 2dr 5 speed a rare find though. Most are auto/4wd that i come across.vg30'd s13 in progress. Shocks. Pegs. Lucky. -
i took them both apart the gearing on the hard body 71c is phyiscally shorter not the gearing the gears them selfs 1st 2nd 3rd 4th 5th are all weakers.michaelp;346960 wrote: This thread is about the 30A, though. And its well known that the newer *240SX* 71Cs are stronger…as for the Hardbody 71C, it wouldn't surprise me if it were the same. How did you determine its weaker by dimensions?
4th gear on Z31 71C is 22mm in length and the hardbody is 19.7xmm in length (the length from front to the rear.)1986 300ZX GLL auto non turbo -
reddzxSenior Citizen- 6440
Size does not always indicate weakness.
1991 Hard-body 2WD
TempastSenior Member- 133
So? Take a look at most transmissions. A bike is a good example. The older bikes (say 1970s CB750) have massive gears, very very thick and heavy, but the engines only make about 67 horsepower. Then there's the new bikes, an example would be a Kawi litre bike. They have very very thin gears in the transmission, yet are making about 197 horse. The gears are made differently to allow it to be stronger and not just strip when you dump the clutch at 9k. Simple as that. Material and treatment.1986 300ZX factory Turbo 2+2 5 speed swap. 1985 Toyota MR2. Floor boards gone. Good fabrication practice.
