oil line auto to manual swap
pabloqc
shromySenior Member- 2189
Use it for what? Your subect is missleading.Hmmm, Whats next?
84ZXT -
I think he means for the clutch hydraulics line, and no…you can't.shromy wrote: Use it for what? Your subect is missleading.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
pabloqc -
Most likely different threads, and yes you can use a full ss line for clutch hydraulics if you find the one that fits.Usual Z31 suspect: Garage Queen (aka broken)
reddzxSenior Citizen- 6440
280ZX SS brake line.
1991 Hard-body 2WD
pabloqc
this one fit if i use the right banjo bolt.
Anyone know the one i need for the clutch master and the one for the slave
Thanks David-Alexandre -
10mm flare ends.. basically a male-male hosepabloqc wrote: this one fit if i use the right banjo bolt.
Guest
That will only bypass the damper. He wants a line from the master to the slave.reddzx wrote: 280ZX SS brake line. -
pabloqc
Its suppose to work anyway i have order it and iam going to try that save me to use a OLD hard line
and if that work at 40$ its the same price as a clutch damper removal hose (280z brake hose)
Z32 piping look longer than Z31 -
hoov100Senior Member- 148
Take the master and slave cylinder fittings to a hose shop and have them put together a hose, probably won't be much more then what that line costs you and it's almost guaranteed to work.shooting for power, but coming up short. -
pabloqc -
1. Buy 3/16" brake line
2. Buy Metric brake line fittings
3. Buy flaring tool
4. Bend line to fit
5. Put metric brake line fittings on line then flare line with proper flare
6. Buy 280ZX brake hose
7. Install 280ZX brake hose on slave-side of line and to slave cylinder.
8. Screw fitting on master side into clutch master cylinder.
9. Bleed clutch slave cylinder
10. Go do burnouts
10 simple steps. We don't need a thread this long for this.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
pabloqc -
silvertonJunior Member- 29
Just for an alternative to a braided clutch line from the hardline to the slave cylinder, this is a PERFECT fit, I dunno how it differs on price and availability, just another option that is out there.
http://www.rx7.com/store/rx7/fcdrivetrain_clutch.html
RP Stainless Steel Clutch Hose1987 Nissan 200sx SE V6 - daily
1995 Nissan Pathfinder SE - wheeler
-Dennis
