Tranny Rear Bushing??
GuardianSenior Member
- 225
Alright so I'm getting my 71c tranny rebuilt, but I need some kind of brass bushing that goes in the trail housing where the yoke is connected. I've gone to my nissan dealership and they can't even get a name. The only thing they can find is a diagram of the rear part of the tranny. The Brass bushing doesn't even have a part number. The manager told me the only way for me to get that bushing is for them to order the entire rear part of the tranny. Which would have costed $350 bucks, but nissan doesn't even make that anymore, so I'm kinda confused on what to do or what to look for. No name or part number. So does anyone know what I'm talking about?
The guy who is rebuilding my tranny said "You have 1-4 gear cluster on the bottom of the tranny and 5th gear is the main shaft on top. So theirs 2 shafts which means their are 2 main barrings in the middle of the tranny. The top barring, which is the main shaft, failed and in doing so, made the shaft move every which way it could. Because of that happening, the brass bushing got beat to hell. And from what the guy told me, he could just throw it back in, but he can't be for sure what could happen.
So part number, name, anything at this point will be helpful.
Thank you for your patience.Originally posted by michaelpI tell them that everyday, "thats a good lifter…good lifter. You want a treat? Oil change next week." But on the other hand, the headgasket is a bad headgasket. Hes always leaking out in my cylinders, making a mess on the cars behind me with all that coolant. So I discipline it with 6,600rpm burnouts. -
G-EJunior Member
- 6320
300zxturboftwSenior Member
- 3709
agree. This is the easiest thing to find. Spoon feeding inc:
Diagram: http://www.courtesyparts.com/300zx-part … _2405.html
Rear oil seal for 71c: http://www.courtesyparts.com/32136-seal … 2391_2405&
plug (not sure if it's the right brass bushing): http://www.courtesyparts.com/009331221a … 47425.htmlUsual Z31 suspect: Garage Queen (aka broken)
CarelessSenior Member
- 13279
please remind me why people rebuild transmissions in this day and age? particularily 71C transmissions? -
- 13279
300zxturboftw wrote: agree. This is the easiest thing to find. Spoon feeding inc:
plug (not sure if it's the right brass bushing): http://www.courtesyparts.com/009331221a … 47425.html -
TempestasSenior Member
- 225
Pretty sure that plug is for the machined hole, like a freeze plug, and no help at all.
I am not sure that part is available. -
- 3709
[quote]Careless wrote:Originally posted by 300zxturboftwagree. This is the easiest thing to find. Spoon feeding inc:
how can you say it's the easiest thing to find. and then say "im not sure if its the right brass bushing" in the same post?Usual Z31 suspect: Garage Queen (aka broken)
