vg33e clutch
  • Quickshift
    Quickshift
    Member
    • 85
    vg33e clutch
    I was wondering what I could do about a clutch if I swapped in a vg33e. I figured I could just look up a clutch for the car I was taking it out of, but I can't seem to find one for an infinity qx4, i'm guessing because it only came with an automatic. Are 3.3L flywheels the same as a 3.0? so I can use a 3.0 clutch? or can I use a 3.0L flywheel on the 3.3L rotating assembly?
    1988 "330zx" 2+2 (daily driver)
  • NissanXRMA
    NissanXRMA
    • 3245
    Quickshift wrote: I was wondering what I could do about a clutch if I swapped in a vg33e. I figured I could just look up a clutch for the car I was taking it out of, but I can't seem to find one for an infinity qx4, i'm guessing because it only came with an automatic. Are 3.3L flywheels the same as a 3.0? so I can use a 3.0 clutch? or can I use a 3.0L flywheel on the 3.3L rotating assembly?
    Use Vg30e flywheel and clutch/pressure plate assembly.
  • Careless
    Careless
    • 13279
    if you're putting the engine in a z31 with a z31 transmission, use the z31 parts.
    a VG33 swap is really as simple as it gets. you're basically just adding 10% more displacement. aside from that- use as many z31 parts that you can possibly use- and it will be easier for you.
  • Quickshift
    Quickshift
    Member
    • 85
    I picked up the vg33e. it didn't come with any accessories, so i guess that's the next thing I have to sort out.
