85 NA CLSD Swap?
 Brootal KoopaJunior Member Brootal KoopaJunior Member- 1
 85 NA CLSD Swap?Picked up a CLSD from an 87T. Want to put it into my 85 NA. Just curious if I need anything else or will it just bolt right up? Keep seeing info about new half shafts and companion flanges but no idea if I will need them or not.
 84Zed31Senior Member 84Zed31Senior Member- 707
 It'll swap right in, no need for new axles. You just need to swap your companion flange on your old diff to the clsd.
 "Let's play Battleship! There's enough Z's for that.."
 My thread thingy: http://z31performance.com/showthread…ep-Zed-84Zed31
 shromySenior Member shromySenior Member- 2189
 As well as keep his original shims on each side, swap ring gear, and add an lsd additive.Hmmm, Whats next?
 84ZXT
